<< Click to Display Table of Contents >> Batteries - General model description |
We have developed a non conventional battery model, trying to avoid the pitfalls which arise in a number of existing PV software: either an extreme simplification, which can only lead to rough evaluations of the system behavior, or adjusted models based on numerous (often interrelated) parameters whose physical meaning is often not clear to the user, and practically necessitate a complete measurement of each battery used. We have therefore tried to fulfill the following criteria :
| - | On the one hand, the model should be presented to the user in a rather simple manner, involving à priori only "explicit" parameters specific to each battery: type of technology, voltage, number of elements, nominal capacity, possible internal resistance and Faradic efficiency, ageing properties. |
| - | Most of these parameters should be available from the detailed datasheets. Others are predefined, specific to each technology. |
| - | But on the other hand, it should be sufficiently detailed to satisfy the needs of the simulation of the PV system, where the charging current is practically imposed by the solar generator. In particular, its behavior in voltage, not critical in the intermediary zones, should be realistic enough at the end of charge and discharge to make the controller operating correctly. Further, it will be important to be able to estimate the ageing and the possible maintenance imposed by the conditions of use. |
othe lead-acid model
othe lithium-ion model
oThe charging / discharging current rate
oThe battery temperature
oThe ageing.
oWith Lead-acid batteries, the datasheets usually specify the capacity at different rates, and PVsyst applies an interpolation function.
oWith Li-ion batteries, we apply a parametrization proposed by Peukert. (this could also be used for Lead-acid in the lack of explicit values).
This property was not known when developing the model for Lead-acid batteries. Therefore PVsyst doesn't take it into account
The capacity decrease is now mentioned on some Li-Ion datasheets. However we have not yet included this in the model, so that PVsyst doesn't take this effect into account when studying the ageing of stand-alone systems. A model should be developed in the future.
One of the advantages of the program is also to evaluate the wear and tear of the battery depending on the running conditions, and therefore the investment to be planned for its replacement. Please also see "Battery Ageing, Nb of cycles"
Ageing is governed by two phenomena:
-a "static" longevity, characteristic of the battery, whether it is used or not. This value is often given by the manufacturer at a reference temperature (20°C). But it strongly varies with temperature, and we will agree with most manufacturers that it reduces by a factor of 2 for a temperature increase of 10°C !
-a deterioration due to use, depending on the number of cycles and the depth of the discharge at each cycle. This is usually given by manufacturers as a number of cycles as function of the depth of discharge. If the ageing degradation effect is identical whatever the depth of discharge, this curve becomes an hyperbola: for each point the total stored energy during the battery life is the DOD * Nb. of cycles !
State of wear (SOW)
During the simulation, for each discharging step, we evaluate a wear and tear increment proportional to the current, but weighted by the actual depth of the state of discharge. The global wearing out of the time step is considered as the sum of these two evaluations.
This is also the reason why on the final report, the total energy stored during the simulation is mentioned on the loss diagram. A good design should aim at decreasing the stored energy (for example by a better load management during the day).
The simulation involves 2 kinds of ageing evolution, varying from 1 or 100% (new battery) to 0 (battery to be replaced): the variables involved are:
- SOWCycl : dynaminc wear due to the number of cycles
- SOWStat : static wear due to the age of the battery.
At a given time, the global state of wear (SOW) is the minimum of these 2 values.
During the simulation, the battery voltage is computed as function of the actual current and temperature.
For the evaluation of the SOC, the capacity is evaluated during the discharge as function of the current rate and the temperature, and memorized for being reused during the next charging period.
Additional current losses (Gassing in case of overcharging in Lead-acid, self-discharge, coulombic efficiency) are also accounted for the evaluation of the SOC. The balance of the input and output energies over a long period - taking all these effects into account, and especially the voltages - will give the real energetic efficiency of the battery during the operation.
The ageing is also evaluated over the simulation period.
The simulation may help for exploring the effect of the control thresholds adjustments, either on the performances of the PV system, or on the aging conditions of the battery.
We can note that for "normally sized" systems, the battery capacity is not a crucial point in the system performance. A little difference may act on the overcharging or PLOL losses, without affecting significantly the global performance.
