List and management of objects
In your 3D scene, all PV tables and shading objects are listed in the List and Management of Objects window. You can open this window from Tools -> List and management of objects or by using the shortcut Ctrl+G.
The list provides sortable and filterable columns for easier navigation. Selecting an object in the list also highlights it in the shading scene. Fields are directly editable, and if multiple objects are selected, changes are applied to all of them at once.
Searching
In order to search specific objects from your shadings scene, you can enter a specific text in the Search box:
The search is applied on the #, Type and Name columns. To clear the search, clear the content of the search box or left click on
Filtering / Sorting
Each column can be filtered and sorted.
To filter a column, hover the mouse cursor over the desired column header and left click on the funnel that appears:
You can now filter the items you want in the pop-up window.
Note that it is possible to filter several columns at the same time.
To clear the filtering, left click on
To sort a column, just left click on the desired column header. This will sort the column in ascending or descending order, and a sort symbol will appear on the column:
Selection
: Select all displayed objects.
You can also select / unselect the objects directly in the list, by left clicking on the objects while holding the Ctrl key down.
When you close the advanced selection dialog, the selected objects will remain selected in the shadings scene.
Expand / Collapse
Copy / Paste
: Copy all selected objects to clipboard.
: Paste from clipboard to selected objects. If no object is selected, the paste will be performed on objects with the same ID (#).
: Same as standard paste, but only applied to visible columns.
Pasting can also be done from an external spreadsheet program like Excel. In this case, be sure to copy the title line and have at least the 3 first columns #, Type and Name:
Edition / Deletion
: Opens the edition dialog for the selected object. A single object can also be edited by double clicking on it.
: Delete the selected objects.
Some fields are also editable, these are cells surrounded by a rectangle:
If several objects are selected, the edition will be applied in a grouped way to all the selected objects.
Columns edition
In order to gain in readability, it is possible to show / hide the columns:
: Select / Unselect columns to show. Also available by right clicking on the columns header. Note that your choice is saved for the next sessions.
Contextual menu
Some actions are accessible via a contextual menu by right-clicking on selected tree node(s):
CSV export
In order to use the data linked to the objects outside PVsyst, it is possible to export the displayed list in CSV format.
