Custom File Import
PVsyst includes a custom file import tool designed to convert external weather data into a PVsyst weather file (.MET) that can be used in simulations.
The main requirements for the external weather or measured data file:
  • The file must be in .CSV or .TXT format
  • Each line must represent the data for one time step
  • Time steps must be hourly or sub-hourly
  • Dates can either be read from the file or generated sequentially.
The tool enables the definition of import protocols (separators, skipped lines, variables, date format, etc.) and allows configurations to be saved and reused for similar files.
The weather data import assistant guides the user through the steps of generating a correct .MET file. The assistant is accessible from the Databases dialog.
Read the Weather data import assistant procedure for a detailed explanation of the import steps.
Launch Weather data import assistant
Available variables
All the following weather variables can be imported. Please note that only POA or GHI can be imported at the same time. PVsyst recommends importing GHI, DHI and ambient temperature.
Name Available units Description
GlobHor W/m², MJ/m²/h Global Horizontal Irradiance
DiffHor W/m², MJ/m²/h Diffuse Horizontal Irradiance
GIPMeas W/m², MJ/m²/h Measured Global Irradiation on Plane, also known as plane of array (POA) irradiance. Plane orientation should then be defined (fixed or tracker)
DNIMeas W/m², MJ/m²/h Measured Direct Normal Irradiance
BeamHor W/m², MJ/m²/h Horizontal Beam Irradiation
T_Amb °C Ambient Temperature
WindVel m/s, km/h Wind Velocity
TArrMes °C Measured Module Temperature
PrecWat mm, cm, in Precipitable Water Column
RelHum ratio, %, ‰ Relative Humidity (0–1)
Linke ratio, %, ‰ Linke Turbidity Coefficient
AoD ratio, %, ‰ Aerosol Optical Depth
Albedo ratio, %, ‰ Ground Albedo
T_DewPt °C Dew Point Temperature
Data processing
Data processing steps are applied to your input data in the following cases:
  • GIPMeas (POA) import : When importing the plane of array (POA) irradiance, a retro-transposition is applied to compute the GHI and DHI irradiance components. GHI and DHI are required for shading calculations. During the simulation, the POA irradiance (GlobInc) will be computed from the GHI and DHI.
  • GlobHor only import : The DHI component (DiffHor) is computed using a diffuse irradiance model
  • T_Amb missing : Ambient temperature can be generated synthetically when missing. However it is recommended to import an ambient temperature measurement.
  • Time shift : see full page
  • Missing data: see full page
  • Quality control : see full page
